Went on my daily commute today and didnโt experience nothing funny, except for this crazy cold wind.
When arriving back home I hear this noise from the wheel and see that the ring of the wheel pulley facing the urethane is bent. I remove the pulley from the wheel and by almost no force at all the ring snaps loose.
Same thing happened to one of my 40t 15mm wide pulleyโs too from the same seller. I reached out for help and got the same answers as above. I threw it in a box with the other new one plus the stuff I bought from johnny261 to go with it and went back to my torque boards 40t 12mm wide dual for now. Perhaps a redesign is in order if the flange isnโt needed and maybe a price drop to reflect one less process.
Happenned to me when a twig got between the belt and the pulley. I simply smacked the ring back on with a hammer as it is a interference fit, added some super glue so it stays put.
Didnโt know for sure if the ring was maybe there to stabilize/align the pulley to the wheel. Now as my motor broke, the pulley will rest with or without the ring.
Titoxd10001 told me he has been using them for a while without as well as a few others. I like the flange and will look into getting it welded back on and making sure the new one is tacked on too. I went back to dual because my belt was skipping and I like the dual brakes better. Dual 15mm is what I will shoot for now on my second deck.
