I’ve got some Orangatang Kegel wheels and my belt seems a little to close to the ground. There’s about 10mm of wheel between the belt and the floor. Is that normal?
I’m running a 15x36t ratio if that makes any difference.
Also, on a side note, does anyone know of a supplier that can make metal wheel pulleys for the kegel? My nylon pulley is starting to wear massively
