Hi, i need to buy the motor pulley for longboard motor. where i can buy on ebay or aliexpress? thanks
thanks, but is very expensive… on ebay and similar are near 7$ any other web page?
$14 is expensive? whats your budget for making a board?
i mean expensive compared with the other pullet which cost me $ 7 and is larger
bigger does not necessarily mean better in this case. you will be much happier if you spend a little more to get the right pulley instead of having to buy a couple cheaper ones to find one that will work.
if you already bought a pulley why do you need another one?
i buyed one for the wheel, and i need the motor one
you got the wheel one for $7? got a link?
how are you planning on attaching that to the wheel? if you dont have access to a drill press or are not very good with just a normal drill its going to be a pain in the ass. also it has an 8mm bore, you’re going to need to drill that out a good amout with a massive drill bit.
Honestly i would say buy a 12mm drive pulley kit from enertion. its a little bit more but it will actually work.
This should work in the motor? http://www.ebay.com/itm/HTD-5M-15T-21W-5-6-6-35-8-10mm-Bore-Pitch-5mm-Timing-Belt-Drive-Pulley-15-Tooth-/252402870141?var=&hash=item3ac462277d:m:mAYkYFrbSLRTga8QCouo7zQ
15 teeth and 10mm
no. that is 25mm wide, that is freaking massive.
plus that is a 10mm bore, you said in another comment you got this motor? That has a 8mm shaft so that pulley wont work for that reason also.
on top of that 15t motor 30t drive wheel is not a great setup and i would be amazed if the motor would be powerful enough for that.
Please, do some more research before you buy things. and when it comes to the drive system. unless you want to make it yourself and are confident in you DIY abilities. just pay a little more and buy a premade system from diyelectricskateboards.com or enertion.
okay , i go to buy the pack from enertion. i use a 75mm wheels. what pack is better for these wheels and this motor? http://alienpowersystem.com/shop/brushless-motors/alien-5065-fr-sensored-outrunner-brushless-motor-270kv-2000w/
if its single motor i would suggest the 12mm drive kit.
NOTE: you have to have wheels that have the plastic on the inside that look like this:
if your wheels dont have that then you need to get different wheels. you can get abec clones on ebay pretty cheap: http://www.ebay.com/itm/Brand-New-Blank-Pro-97mm-Longboard-Flywheels-Lime-ABEC-7-Bearing-Spacers/151887083729?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D36866%26meid%3De6ad0e2c0cea431a9e5a968553db0190%26pid%3D100033%26rk%3D3%26rkt%3D3%26sd%3D252402870141
okay thank you. buyed
what charger can i buy? i want the most cheaper…
this charger should work? http://www.ebay.es/itm/iMAX-B6-LCD-Screen-Digital-RC-Lipo-NiMh-Battery-Balance-Charger-AC-Adapter-New-/361425168248?hash=item54269e6778:g:G-sAAOSwBLlVVhPT
probably. but like i said before, you want to be careful with going with the cheapest option…
they are too expensive,please stop,they are overpriced for this who don’t know what they need,you can get motor pulley,wheel pulley,belt and motor mount something like 15-20$
