New to Skateboards but i been Doing Rc Cars and Drones for years …now I’m building a board with a dual 6374 setup and looking for speed and power to pull my 215lbs around …i am about to attempt to build a battery can anyone tell me which bms i might want to use such as Amperage 60 or 80 …thanks for any input
Depends what cells you use
i am going to use a high drain 30 amp 18650 of some kind i am assuming …while we are at it may as well tell me the Best cells to use I’m already 2k deep into this and i had all the tools and supplies i could ever need to build …maybe i should have just bought a BAJA Board LMAO
I dont think so. Now you have the ability to customize the board to your Needs and build more in the future! that is a huge plus
Dual 6374 is not 2k deep without battery bro… Were u getting your parts
I’d say at most you would spend 1.5k with battery,
A regular 12s4p from Baja or torque boards should be fine being that much of high amps and never going to use them , just a thought.
thats exactly the battery i was going to buy thats why I’m asking about this before i pull the trigger
If you just want to ride and have fun and occasionally hit 32+ get torque boards battery , If u are a adrenaline junkie and want to ride fast get @barajabali battery pulls more amps because he has a higher amp BMS and you can request it to be bypassed if u choose
i think with everything from diylectric skateboards 1449 then i figured abec11 107 wheels and i bought 2 long board decks i liked them both so i bought 2 ,i figure I’m going to be right around 1800 to 2000 when i get done ,i
im a speed freak my last 3 cars make 700-1000rwhp i can’t have slow board and I’m not a small guy ,I’m gonna look like sasquach on a skate board LMAO
so is the stuff from DIELECTRIC skateboards ok to use ,honestly its easier to just get majority what you need from one vendor when possible
u r speed freak ah?, lol with esk8 when u pass 35mph u will starts to feel death. I mean if u can go without speed wabbles before that (do bushing setup before u try) baja use 8 giant lithum iron cell which out puts less amp than 30q 12p4s. thats why they use 4 seperate kelly controller. this thing is freaking high off ground without straps no thanks.
and on side note, when u thought it is enough you’d wants more torq more speed in the future
@Hellcat17 - Go with the 12S4P. It’s double stacked though to fit within a 26" wheelbase deck. Otherwise, you limit the type of decks that will fit all your components. 12S3P will be discontinued.
Next build I’m going to try and build 4 motors front and rear 6374 with 16/32 gearing with dual 12s2p packs if I like how this setup comes out with a 5 channel Rc car radio and reciever with motor rpm and motor temp and battery voltage and speed connected to BT , I have tons of ideas from my RC car and drone projects not to mention I have a ton of friends in the auto fabrication industry with mig and tig welding experience and CNC lathes …I’m jumping way ahead here though i need to finish 1 thing at a time here Lmao …Thanks for all the input guys
Hi ! Do you’ve built a fast sport eSk8 ? Cause I want to build one that can reach 60kph minimum, I can reach 70kph may be more now (because I’m better than last year) on a normal longboard. It is hard to find some example of config on the web… 20kmph is cruising for me… I’ve tried some normal eSk8.
I just want to say going fast on a car is easy putting your ass on a stick of wood going 30+mph with no weight to back it up you will feel death. It takes skill to ride or stabilize at that speed
well I own a quite few boards my fastest board can hit around 60 mph(106kph) never bin there but I cruise around 30mph(48kph)and I’ve gone up too 42mph (67kph) last time I checked. it’s a 4wd carvon evo 12s6p 30q bms bypassed
here’s a clip of me riding I don’t want to derail this thread but I all ready made a thread build about it if u want to look it up
I’m in the same boat dude, this shit is expensive fml
But so fun, and its all about good quality at the end of the day… I hope!
