Hi,
what is your prefered KV for your ESK8?
I am curious what is your oppinion on that. Please tell me the Voltage of your batterie as well.
At the moment I think 230 KV should be the best for a 10S Setup.
Reason to ask is, that I am thinking about to order one custom 6374 KV motor (or 2 x 6355 for dual drive).
Other option would be to buy some more motors and resell it here for non profit. But therefor I have to know which KV are favored.
I’ve only got a few belt drive boards but my motors are 190kv at 10s3p and it runs like a champ with no lack of hill climbing torque and no signs of heat
I’m pretty sure the min is 50x-100x for custom kv.
but if you’re going for it. try something different.
plenty of 170, 190, 200, 245…
maybe like 220. or 140…
and of course there is delta vs wye.
almost all motors are delta…
Not necessarily. This limit is only for not destroying your VESC. What the optimum KV for you is is defined by how fast you want to go. Choosing a too high KV will mean that your motor runs too slow / at a too high torque load and that will lead to a significant decrease of your range since the efficiency is low!
A custom motor puts you in a good position. Most motors that you can buy off the shelf have way too high KV for typical ESkate gear reductions. Then people have to get tiny motor pulleys, which leads to skipping belts and so on and so forth.
You should decide for a gear ratio with a decent number of motor pulley teeth. Then decide for a top speed, and calculate what KV you need assuming that this speed is about 90% of the no load speed of your motor at the voltage that you use. This way you get a perfect torque-speed balance. Even if you live in a flat area and you think you don’t need a lot of torque, a low KV motor will run more efficiently because it runs closer to the no load speed, and you’ll get the maximum range out of your battery.
