Need to know so I don’t fry a BMS!
Cheers in advance!
Cheers in advance!
Easiest way to check is to plug in your charger and then use a multimeter on the terminals to determine which is which… Generally the centre pin is positive.
i always check the terminals with multimeter after i plug in the charger. thats the best way i think
