I have some background knowledge about programming (arduino and C) (not much tho) (I study electro highschool engineering…)
I started doing prototype control with an original wii nunchuck, and a servo motor (as throttle) and it worked! But whenever I plug the wireless nunchuk, the module and nunchuck bind, but there isn’t any data going through. Only the indicator light on the module blinks when I press one of the buttons on the nunchuck.
Can anyone help me? Does anybody know where to direct me? Maybe I need to change the Baudrate? If anyone has any comments on my setup feel free to help im still new to this.
Sorry for English mistakes there must be a ton… I live in Europe by the way.
What are you plugging the nunchuck receiver into? Maybe more specifically, what device would you be changing the baud rate on? I’m pretty familiar with the setup on the vesc, but it doesn’t look like that’s what you’re using…
thank you for your offer i live in europe so i guess the shipping would be on me ;). But the point is that I resove problems by myself or with your help (thank god i found this website).
I plug the nunchuck reciever tho the I2C pins on the arduino (in my case analog 4 and 5 pins, 5V, and gnd). I use an old wii nunchuck library that works.
Got it. Just trying to get the whole visual. Sounds like you’re going to use the Arduino to turn the nunchuck’s signal into a pwm signal for the speed controller. Good for you!
My gut says try the baud at 9600. Can you link the Arduino library you’re using?
As far as im aware only the nyko kama or memorex brand wireless nunchucks work. It was something to do with the code i think… someone on here found it once but i didnt hear much back from them.
Really? That would be awsome! Always good to have a backup if anything goes wrong. Like I said this project is still all about me making the thing because I’m being graded a month later, I have to report what I’ve done…
Yes I saw that post, I am using a cheap little adapter from ebay. However the code provided there doesn’t work, or I don’t understand it or how to use it…
Found the original Austin David code, I seems to work fine, (I havent motor tested it yet, but the motor works) I love to code, and I will most likely use it all the time. I have a little problem though, my nunchuck isn’t calibrated (the neutral joystick position is not zero, serial monitor says 0.1667). If I plug the classic wired nunchuck, the neutral position is 0.1200. so I guess It’s fine?
