Will a 6s BMS work with 2x 6s LiPos in parallel?
As long as you connect/wire each cell parallel to the corresponding cell in the other pack and then wire in the BMS. Then it would be a 6s 2p battery pack
what do I do with the balance leads? solder them together?
I have this?
You need to splice the balance leads.
And this.
Do you mean solder them together?
Yeah. Or get a parallel charging board if you dont want to solder them.
OK thank you
I got worried for a minute because I have already ordered 6s BMS and 25.2v charger
What would you call the connector?
thank you.
