Hey will this loop key work, im using xt90 s connector.
Because i know some people been say loop keys have been burning or not working properly, so im bit nervous about wiring it up as i might make a mistake.
Yes, it will work.
thanks but will it eventually burn out, because I’ve read a few posts about loop keys smoking up and breaking??
I have never had a loop key go up in smoke. As long as the solder joints are good nothing should happen. If it’s a cold joint or not a good connection it will eventually wear away and cause sparks.
I make mine the other way around. Male xt should be the passive side, the key. They’re also cheaper so you can make extras…
The female with anitispark circuit is less likely to get shorted, you really have to try!!! So that should be on the power side.
True but very rarely would it ever get “shorted” by accident. Plus the female XT is easier to plug in. Also, even if both prongs somehow got touched, it would only complete the circuit, not a “short”.
Yes but it would complete the circuit without the spark protection. Kinda the whole point…
It’s just better practice but either way works.
Im not disagreeing with you but I’m just trying to prevent people from thinking that not using the Male XT as a key will result in smoke/fire. Like you said, either way works .
I’ve been using an XT90-S on my main build for months and a double kick build for a couple of weeks. I’ve never had a spark and both work beautifully.
Connect the XT90-S in line with the POS wire after the battery but before everything else and you will be good. Hundreds of people have done this with no issues.
great thanks
What AWG are those wires? They look really small…
16awg
yh they look small, i don’t know why they look bigger online
Are those 16 AWG wires your main power lines? If so I’d recommend using 10 AWG, or 12 AWG at least. 16 AWG is only rated to about 22A
Keep in mind these are conservative numbers, but this chart is a good guide. You can exceed these values because we are not continuously pulling high current
ok I’m gonna change them now thanks, could I use copper core awg wires btw ?
Yeah those will work fine. Silicone wires are usually preferred, since they are more flexible and the insulation has much higher heat capacity (won’t melt during high temp soldering). But they are more expensive and not as readily available
The copper core are smaller for the same current capacity. The wires stay in place, which can be a pro or a con depending on the situation
Cool great advice.
Im also having trouble using my controller for setting up my vesc. Its PPM on the bldc tool right or is it UART?
Anyway when i accelerate with the controller the motor literally jumps like crazy, what have i done wrong?
I connect the vesc and uploaded the right firmware, what do i change so my motor reacts normally to my acceleration?
About your loop key. I can’t tell if you have it before or after the charge port wire. You want it after the charge port wire.
Do you put the positive side of the loop key to the battery or the negative side? Or does it not make a difference?
