I just ordered all parts and it is all in a very early stage.
What i´ve planned:
- 4 wheel drive hub motors (@jacobbloy) to get awesome hill climbing abilities (i hope so)
- Hi-output battery with INR18650-25R cells (BMS-Limited to 100 Amps)
- 4 OllinBoards VESCs with Heatsink
- Custom hollow board to hold all the stuff
- Nunchuk controller(because it is part of Jacobs VESC Connect BETA program)
I will update this post soon with some drawings.
First deck design (without core):
Dimensions:
Length: 110cm
Width: 24cm
Wheelbase: 86cm
Usable space for components:
20X75cm
I bookmarked this shit…this is gonna be EPIC!!!
i hope so
if i fit everyting in…
That is why they invented duct tape sir…
Just ride that beast … Full video and if possible multi angle…that would be great…Thank you lol
hmmmm… I’m planning a similar build using hummies motors. Would be interesting to see how they compare the two.
I´ll do so, i own two dji phantoms and a bunch of gopros^^
@evoheyax that would be a great comparison, the only bottleneck on such beasts are the motors
Have you placed your order for the 4 hub motors? I don’t remember seeing an order for 4. Sale ends soon
well two kits with two motors i think
Order Nr #613 or #615 @jacobbloy , both are mine but i dont remember wich were the motors
Ok cool I’ll check it out! Got a couple of other guys with 4 motors out there but there all waiting for vesc. I’m trying to make a 107mm wheel for one customers 4wd setup.
That would be awesome but could be a bit wobbly just sliding / clamping it on.
And it will definitely only work with 4wd apart from that you cant climb any hills
but i hope you succeed … i want some
On shit can’t wait…
Full leathers please…just in case there are some bloopers
I want this to work so bad lol. We always say 2wd is awesome…when it works.
4wd might be a juggeling act.
You could build 4 solid boards with that much tech lol god bless
@Michaelinvegas Oh yes, i am going to street my face often
@barajabali well i think this is more like a proof of concept.
Nobody will ever really need so much power
Streeting your face (SYF) = No Bueno
But sometimes needs to happen^^
Sweeeeet!
Looking forwards to seeing what you create
Another small Update:
I killed one of the parallel packs, just ordered 6 new cells^^
