Hi,
I’m in quite a pickle here I have bought 2 6s LiPo’s (wiring in parallel) and a 6s BMS (bypassing discharge) this was how I was originally going to wire (when I was going to buy 2x 3s)
I think you kind of have it right. You are bypassing ok. And you are paralleling the thick wired and the balance wired of the batteries. If your bms is for 6s and only had 5 pin for balance connector it means it doesn’t carry the positive or negative on the balance. So ignore the red and black from the balance wire on the batteries (they should be that colour. One on each end)
Pro tip when not sure about writing Lipo batteries and asking… wait to have a bunch of people agreeing on an answer before you run to wire…
In a 6s pack you havea thick ref for positive, a thick black for negative and 7 small wires for balancing. Of those 7 wires one is connected to the thick red (and is usually also red) for the positive balance and another one is connected inside the battery to the thick black (usually also black) and thus this 2 are not always necessary if your bms already had positive and negative through the thick wires. So in occasions bms have connection for Less than the expected 7 balancing wires.
The other 5 balance wires are the between cell connections.
You can paralell batteries by combining colours if the are same model because they should respect the colour coding but I wouldn’t risk if. Better measure voltage between negative black thick wire and each balance wire. If should be something like. 0》3.8》7.6》11.4》15.2》19》22.8
