It’s been reading through some of the topics and comments, I thought I could take advantage of everyones knowledge myself now.
I am looking to build a dual motor board. I live in the UK. I will use the board on roads, paths etc. These can be a little rough at times and aren’t perfectly smooth surfaces.Trying to keep my costs down as much as possible and will happily upgrade/update in the future when I can.
Deck: Still haven’t found what I am looking for. Some suggestions would be welcome and links to websites. Not looking for a big board.
Trucks: Flipsky - Double Kingpin Trucks (Includes motor mounts)
Im looking for a simple deck like this: https://www.longboardsuk.com/36-kicktail-blank-deck.html?cf_chl_jschl_tk=c4ef653cae6ef3de95144345ace734648542b82e-1617710229-0-AReg0WRcBlOb5c-kS-7eOh3ptfIGEg2AGS_jzBXfcZllOQCGsY04BSzwk7Yl_X_Q9Iz2E_PmrkbQ3dkhocpudF7lykZnKvAWvKiSSK6Jalx5kKcHS7_Uob4rtBxKSdg-tSQQ6NV-JBqqLYr9PqHEO7lV_zXxP_SdK8UrDFFKE0v8ErLpSe9ydHn3o_H2rKmW6zjeRq0XI54h8dOXLgZfv___GIVjzOQ7LrPNp7VOp49_mcO8rGglesgDsVNxvXSQUti5AUHbWSQs3cW1QIYEL0hcGXn_0kp9dfdNeo25-P6sZZq8T392VRw5pR7RKfy6sosOE-5gvg7oyIKMFN_vSt_0dzMTUFQP-pLdH4nONSjmYv10a3L3mCiFXXspuM2zLhdlu17PTCwKXNd9EwbtfLAgnnsg5v8-FBOe6fNOY4nu
iff you haven’t ordered your battery yet from Mboards i would also be willing to build you a battery. (this would take some time though given that i don’t have the parts in stock atm so i would have to order them on demand).
i don’t have any expiering with them so you would have to ask someone else
i mentioned them because they were the suplier u mentioned u were looking at
Hi there, nice to have new bro here. 110mm are big wheels and 190kv motors has plenty of torque, but rpm’s on higher side. What is yor calculated top speed? And what max discharge rate for your batteries?
Im working with a custom battery builder to get a battery with works with all the motors well. The bigger wheels came about due to surface of the roads and pavements/paths in the UK. I might drop down to 97mm.
Well my story, i have 12s single 192kv motor. First time i got 97mm wheels as in Kyiv roads are bed. I got 15t pullet on motor and 40t om wheel, and i felt max speed to be too high, and i wished to have less top speed and more torque, nut i couldnt use smaller motor pulley besause of belt skip(i use 3d printed pulleys and i was told it might be te reason of belt skip, and eventually i added bearings to tighten belt). Now im on 83mm wheels and i prefer them over 97mm. I did not noticed HUGE change in riding comfort, but torque improved a bit. You are yousing to os similar motors, so might be not an issue. My main idea to not look for biggest wheels but check other specs with same importance. So what output oc your battery, how many A?
