Hello Guys, I’ve recently been hard at work with my most recent builds (see other: http://www.electric-skateboard.builders/t/carbon-stealth-bomber-dual-hubs-dual-vesc-10s3p-18650-freebord-bindings/8657)
I am also working on this board. The Juggernaut. Named that way because of the massive power this thing has. It is a dual diagonal setup using my 6378 motors (not yet in. Going to be using a single 192 KV SK3 for now) It will (probably) have an 18/36 gearing and it will run at 10S. The battery is a custom made li-ion pack, 10S3P. The enclosure is a Psychotiller custom. The trucks are caliber II stained green. Wheels are 90mm flywheel clones. I will be using Enertion pulleys. The motor mount is currently undecided, but I will most likely be using a custom mount.
As for lights, I am using LED strip lights from hobbyking that can be controlled by a standard RC remote. I am also using shed lights as headlights. A little expensive, but the luxury is nice.
Current Pictures:
