Opinions on this space efficient packing set-up? 12s4p
ehhhhh that would be way to difficult to spot weld.
I donāt have a spot welder so it doesnāt matter anywayā¦just gonna solder with 10/12 AWG because thatās all I can do
hehe youāll rethink that decision, solder just dosdent stick well trust me (i tried it with 30 hg2ās didnt go well) and it degrades the battery by a preety decent amount
and is that the new asus zerphrus?
Nahā¦Scar I from costco
Already broke it skateboarding from classā¦Iām devastated
Haha it seemed like it for a second.
Whatcha did?
Banked a bit to hard to avoid the road and the wheels hopped over the asphalt/concrete transitionā¦rolled onto my back and the corner of the case has a tiny crack to show for itā¦lost all 3 of my mechanical pencils so I had to use a normal pencil like a peasant
oof hurts man, should just get a uni kuru toga, pencil those pencils are the shit.
Ooh thatās a sexy pencilā¦love that 0.5mm
i think they have a 0.3mm version i love those because they make my hand writing look good and i can write at any angle perfectly.
Damn, Iām sold
plus its a engineering marvel, it rotates the lead every time you press down so youāll always have a sharp pointā¦
i feel like a salesperson
Sure! Just make sure each P-group gets two of the brown cells and three of the green cells.
That was a mock upā¦ I never mix cells of different ages or different capacity.
Iām guessing 30q and 25r donāt work well togetherā¦
Soldering the cells does work; you donāt HAVE TO spot weld, but itās highly, highly recommended
Iāve tried but failed, solder just doesnāt sick as well as spot welds lol
They would work together if matched in the P-groups, but itās not recommended and Iād make sure to have a very robust balancing system (at least 150mA) if you did that.
Itās far better to use the same make & model cells for the entire pack, and the same age cells.
Did you rough up the surface or use flux paste?
Yesā¦ I used 100 grit sandpaper
The pack that I have at psychotiller is a 30q pack 10s4p around 3 discharge cycles so it would be fine to add 10 new cells.
With 3 discharge cycles it shouldnāt be a problem, as long as you have a BMS that balances the cells
