Hi everyone,
First time on here. Wanted to get some input on a possible replacement for a wowgo 2S hub motor. Not sure exactly what options I have for replacing the 90mm hub with a non-discontinued product. If there are any alternative manufacturers that work with the wowgo board, that would be okay as well. I’m just unsure of exactly what version of the hobbywig esc this board runs.
I appreciate any help you could provide.
(Already tried a replacement but the motor failed after a month of use. (Hence the newer looking motor) Wire colours didn’t match the original but still allowed the board to function for a little while)
