As the title suggests I need 8 x 15t, 15mm, steel pulleys, 8mm bore, no shoulder, single or double flange, no keyway or grubs needed but it’s ok if they are on there.
I’ve seen loads of aluminium ones for sale and eskating.eu can customize what I want but lead times are an issue.
If anyone has any or a link to where I can get them that would be great! Thank you.
Beltingonline can do whatever machining is required and they are like 15 mins from my house but I swear the lady in customer services just cannot understand what I want. Am I being unclear here?
15mm wide, 15t, HTD5M, 8mm bore, with flanges, without hub, without keyway, without grubs.
She keeps asking if I want it 9mm wide, I’m so confused!
I have 2 unused 15T 15mm wide, 8mm bore no shoulder pulleys with double grub holes bought from eskating.eu if you need them.
Got them to use on my psychotiller mounts but settled on 12mm.
Just ordered Jared, yours just work off the shelf. I’ll exercise some patience - If you want to chuck some 44t pulleys into the package for the modular set you sent at christmas that would be cool
