Due to medical conditions I wont use my build anymore and dont want to keep it
1x 35° TRAMPA Carve Board Deck
16ply SOLID Carve – STIFFEST
2x VERTIGO Trucks
BLACK Powder Coated Springs
RED DAMPA’s Stiff
4x 6.5Inch TRAMPA Urban Treads Tyre & Tube
5 Spoke SUPERSTAR Hubs
WHITE Gloss BLACK Logo Superstar Rim
RED Anodized Spokes
2x RATCHET Style Bindings
Black Strap with Black Foam Footstraps
RED Powdercoated with BLACK logo
RED Powder Coated Ratchet
1x Motormount Connector Panel & 62 Tooth Pulleys
1x BEAST Box to fit 2x 6s with Internal VESC Housing
1x Luxury Travel Bag
1x Dual FSESC6.6 Plus(Pro switch) based on Dual FSESC6.6
Spec:
Voltage: 8V - 60V (Safe for 3S to 12S LiPo) for the dual ESC
Voltage spikes may not exceed 60V
Current: Continuous 100A single, total 200A , Instantaneous current 400A per single, total 800A for system instantaneous current
Modes: DC, BLDC, FOC (sinusoidal)
Supported sensors: ABI, HALL, AS5047
-ERPM:150000
-Size: 78x78x20mm including heatsink
2x Flipsky BLDC Belt Motor Battle Hardened 6374 140KV 190KV 3500W
KV: 140/190KV
Max Power: 3500Watts
Max Current: 85 Amps
Max Volts: 12S
Max Torque: 8Nm
Motor Resistance: 0.05Ohm
Net weight: 980g
1x Screen Remote VX2 Pro compatible with VESC
Features:
Color screen
Option choice for km/h and miles/h
Option choice for FSESC and other VESC( FOCBOX)
2.4Ghz band width
Real time data reading and 0.95OLED display
Support 3 speed modes
Support cruise control mode
Remote and E-skateboard power indication lights
Rechargeable Li-ion Battery
Wrist strap
Battery last for 12 working hours
2x Turnigy Graphene Professional 8000mAh 6S 15C LiPo Pack w/XT90
Specs: Capacity: 8000mAh Voltage: 6S1P / 6 Cell / 22.2V Discharge: 15C Constant / 30C Burst Weight: 1110g (including wire, plug & case) Dimensions: 170x69x48mm Balance Plug: JST-XH
1900€ price negotiable
