Built for a board that did not see many miles, though I’d free some space
USE:
- equivalent of 3 full cycles, verified balance after (8 partial cycles over short trips, between 20% and 80% charge). Stored at 37V for the last several weeks
MATERIALS:
- Samsung 40T cells (new)
- pure 15mm x 0.2mm nickel
- DALY 15A split port 10s BMS
CONSTRUCTION:
- folded nickel series connections
- parallel connection on negative end, folded over can for balance tabs, welded ontop of series connections
- double insulated positive terminals
- 5.5mm series bridge and terminations, XT60U adapter included
- 6 pin (5s) balance lead on blocks, 11 pin (10s) adapter included
- continuous fish paper wrap and single piece shrink wrap on blocks
- 3.5mm bullet BMS leads
- 2pin JST charge connector
- waterproof 5.5mm x 2.1mm barrel charge port
DIMENSIONS:
- blocks: 381mm x 69mm x 23mm
- total: 395mm x 175mm x 23mm
PRICING:
- $299 plus shipping (TBD) and fees ($9)
- shipping via UPS or FedEx ground in contiguous 48 states only
- 3x same batch spare cells for $19
NOTES:
- blocks feel solid AF, they do not bend under their own weight
- blocks can be soaced or rotated to accommodate enclosure dimensions, small ESCs or other componentscan be placed between blocks
BONUS DECK:
- Tomiboi V1 integrated drop mount deck, damaged lid
- Weight: 6 lbs 7 oz
- Size: 38.25"x9.5"
- Wheel base: 29.25"
- donations accepted and will be forwarded to Tomi
- leaves plenty of room for dual ESC
