I am at the battery stage of my build and trying to figure out which one is the best option. Should i buy a 10s LiPo battery pack or should i buy two 5s Battery packs and make them into a 10s series. Or is it the same thing? are there any extra benefits?
I was thinking if i buy a 10s lipo pack i can wire it in parallel to another 10s for more board time? would this work?
it’s the same thing except when you buy 2x 5s you can swap from parallel to series.
And when one cell goes bad. You only have a 5s pack that is bad instead of a 10s pack.
would go with the 2x5s
ahh okay thanks. what if i wanted to parallel two 10s batteries using this setup… Would i have to series two sets of 5s batteries and then parallel them up? or wouldn’t that work?
YHi I am trying to make a eskate board on a budget and need some help choosing the best lipo I want to used 2 motor and 2 esc (cheap ones) without burning them out on the first go these what I have buy already
High quality Anti Spark switch
NEW Detachable Led Switch
4 oz PCB
Safe for batteries up to 12S
12AWG in/out wires always pre-assembled
40 to 100amps fuse (optional)
XT60 or XT90 connectors (optional)
Led switch in different colours (optional)
Motor
Schaltet: 18T
Spannung: 10S Lipo
RPM / V: 190kv
Innenwiderstand: 0,028 Ohm
Max Belastung: 65A
Max Leistung: 2450W
Wellen - Ø: 8,0mm
Bolzenlöcher: 32mm
Bolzengewinde: M4
Gewicht: 697g
Motorstecker: 4 mm
ESC
Max Cont Strom: 60A
Max Burst Strom: 80A für 10 Sekunden
Eingangsspannung: 2-6 Zellen Li-XX oder 6-16 Ni-MH / Ni-Cd - Batterie
BEC: 5,5V / 6A Switching BEC
PWM: 8 ~ 16 KHz
Max RPM: 240,000rpm für 2 Pole Brushless Motor
PCB Größe: 50x32x12mm
Gewicht: 63g (inklusive Kabel)
** Programmierkarte benötigt Einstellung zu ändern
