I’m making a loop key for my lipo setup and I’m finding the key is really stiff and difficult to remove. It doesn’t just alot into place, you have to put some serious force behind it in order to separate the two.
Has anyone else experienced this? What did you do to combat it?
After u break it in, it gets easy… I use my board daily and after about 2 weeks it goes in just fine… Mine is also epoxied into a case so you only have to pull the loop side
I take needle nose pliers and squeeze the male side of the xt90. a little goes a long way: they will still be secure, but slide in and out a lot more easily
Someone please make and sell these . I’m about two clicks away from buying a 3D printer so I can have what I want when I want. For now i’d Like to just get 1 piece. And the female side for mounting too.
