Hey I want to connect both focboxes together is this the right way for my xt90 connectors for my current?
or sth like that? (https://hobbyking.com/de_de/xt90-battery-harness-10awg-for-2-packs-in-parallel.html?wrh_pdp=3&___store=de_de) think its exactly the same, isnt it?
Yes it is, but you need 2 female on one side and 1 male on other side, the one you linked is 2 male and 1 female
ah yea oke perfect thanks
You could use xt60s on the focbox though no?
Choose: I WILL USE IT FOR DUAL VESC SO DUAL FEMALE FOR OUT VESCS AND ONE MALE CONNECTOR FOR BATTERY
yeah i changed it to xt 90 because everything else on my setup is xt90
I dont think it makes a real difference at the end
Just if space is at a premium. 3 x XT90s can take up a bit of room.
Ill just leave this here
to bad if you wire***it this way in the enclosure its almost the entire inner height…
What?
Doing it this way because im very limited on space.
ah nevermind
i cant find the words… too early
@seaborder Just be aware that if you change anything on the focbox then you void your warranty. Best leave the xt60’s on there and use an xt90 s for the battery with a y splitter like @Skunk showed.
I created this. Is that ok? The picture is simplifed a bit.
Thanks!
check this diagram out, might make it easier for you…
Is that a 12S5P setup diagram? That’s a pretty good detailed picture.
It is, the entire diagram includes balance wires, Rx, BT, etc. I’ll post it when it’s complete.
