oh damn, that works too? sweet.
I will NOT run any of my VESC on split PPM. Not saying it doesnt work, not saying it deep fries anythingā¦
I first setup on split ppm(easiest) -motor startups were off (not in sync) -sometimes only one motor would spinā¦ -no traction control/rocks flying when tire lifts off the ground.
Now the ppm signal goes to a switch. position 1 is PPM to master VESC position 2 is PPM to slav VESC
Position 1 is dual drive, through can-bus. The master handles the PPM from reciver and passes signal through can bus to slave.
Position 2 is PPM to slave only. this allows only the slave to drive.
If the slave motor/belt/VESC fails, I can remove the canbus connector and drive only the master without conflict. If master fails, i simply switch to slave only.
I use the Traction Control function so if one motor is lost the other must be shut down to avoid rpm conflict. (rpm difference causes timeouts when on TC)
If anyone has trouble setting up can-bus to dual VESC 4.xx please let me know and ill post a step by step.
āmotor startups were off (not in sync)ā Iāve only noticed this while bench testing and barely nudging the throttle. If I pull more throttle, they start up together. Anyway, it is completely unnoticeable while riding.
And if one of your wheels is lifting or loosing traction while turning, Then either your trucks are too tight or your bushings are too hard.
Would love a step by step for setting it up. I am in the middle of deciding to go with a @Jinrasā option or to go with CAN.
Ive written out 14 simple steps for setting up dual VESC using CAN-bus with bldc tool. With VESC-tool, its one click of a button during the setup wizard
Here are the steps I used to program two VESC to communicate through CAN bus. Using the BLDC tool, and two 4.12 hardware VESC.
1.) Choose a master/slave ESC. label accordingly. 2.) Open bldc tool and CONNECT to master ESC. 3.) open app configuration/general tab, and read config. 4.) set controller ID to ā0ā, save config. 5.) Choose the appropriate tab for your control type(most will use ppm) 6.) Select the box that reads āmultiple esc over canā 7.) save config. 8.) Dissconnect Master, and CONNECT slave esc to bldc tool. 9.) open app config/general tab and read config. 10.) rename the controller ID ā1ā and select āsend status over canā box. Dissconnect. 11.) Connect your canbus cable. I recommend the proper connector/jst-ph 2mm 4-pin 12.) Reconnect Master ESC to bldc tool and read config. 13.) on the right side of bldc tool under the dissconnect button, select the slave controller ID (1) and select the CAN Fwd box. Write configuration, and dissconnect. 14.) Reboot both VESCS and test controller, if only one motor spins, check to see that the āapp configā settings for one VESC are the same as the other.
Not on the slave, only the master
Long debateā¦
When thinking about Y-PPM or CAN, you also should think of single battery or twin battery, each powering your ESC. Split battery is better for Y-PPM, since there is no common ground. This could even work on VESC Six.
@Pimousse mentioned it before and itās quite important to know, also for CAN setup.
There are pros and cons for both setups.
Frank
edited* ty Yes there are def benefits to both. Most wont need Traction Control which is the real benefit to setting up CAN-bus. @Namasaki Its hard to keep the trucks loose for fine control when moving 40km/h top speed. When traveling over gravel/loose terrain is when the TC really shines.
With the right after market bushings and pivot cups along with precision bushing washers, you can have decent maneuverability with stability. Of course it also depends on your ability and endurance. core balance, ankle and leg strength. Ever notice how you seem to have less stability after riding a while. Having your trucks too tight can get you in trouble when going fast on curvy roads.
How is running dual Vescs on a parallel power connection a problem when feeding them a parallel ppm signal from the receiver? How does having a common ground have anything to do with them both being fed with the same ppm signal?
I have never heard of anyone killing a Vesc4 with parallel ppm. As long as the receiver is powered by only one Vesc.
And running separate batteries. Think about that for a moment. dual batteries dual bmsās dual on/off switches dual charge ports dual voltage meters and twice the wiring Not very practical in my opinion.
can bus yo.
da fuck yall even talkin bout shiiiit
lblblblbllblblblblblblblblb just run that signal wire on over you donāt have to worry about grounding shut yo mouth. not a problem with can bus shit
dual fires lol
I didnāt say there is a problem with canbus, Iām saying there is no problem with parallel ppm. However, either one of them if not set up correctly can damage a Vesc.
BTW, glad to see that you survived your run in with Irma. Hope you didnāt suffer any loss.
a shorted can bus will ruin your whole month for sure.
iāve been drinking.
heavily.
yes we can tell.
What about connecting one remote to 2 receivers?? I have 2 enertion nano x receivers laying around so could that work ?
yes, just pair both receivers to your one controller.
