drivetrain looks great, by the way
The motor pulley is 15t 15mm from APS
The Mount is cnc milled out of aluminum and the motor is a 280kv 1.5kW from Turnigy.
And the clamp for the wheel pulley is made on a lathe.
That,
Looks fantastic
If the rest of your 1st build is of the same quality, it’s going to be great
The deck is from amazon for 40€ and I don’t why the trucks of this longboard were complete garbage(not mine for the build). I’ll try to sell them. The quality of the deck for this price is ok. I’ll post some pics later.
I will put 6mm riser pads from APS under the trucks to have a bit more ground clearance later on.
Make sure to take excellent care of your batteries and VESC.
I want to start coating my ESCs and BMSs in conformal coating like @b264, you should probably do the same
Does that mean, that I squeeze some silicone or with hot glue into the gaps to seal it? I plan to route the phase wires through cable glands.
Specific materials are needed for effective waterproofing and efficient heat transfer
Hot glue for the little holes in your enclosure is fine, silicone would probably be best
“neutral cure silicone” like “GE Silicone 2+” maybe but definitely never use hot glue
Might wanna use tupperware or fiberglas for the enclosure.
facts, I got mine today
I had today the first testride. I used a f’in shoebox as a enclosure Works pretty well so far.
Does it matter if I put l the put loop key out of the enclosure, hanging freely in the air?
in the enclosure will be harder to remove in an emergency but with it out it could come lose unless its attached properly
Make sure the wiring that is touching the outside of the enclosure won’t wear through the wiring and it should be fine. And it won’t get caught on anything.
Probably I would make a lottle bit stiffier to ensure durability of the key.
I’m almost done with it. Last but not least I have to screw down the boxes and then put back on the motor mount with some Loctite. Build quality is decent, I think.
Well done, bet you can’t wait to take it out.
I bought myself some orange 80a Kegel’s after I saw yours, and love em
Yeah really, as said before, I had a testride and drove along a rough street and lost some screws from the motor mount and then the set screws from the motor pulley came loose and then I had to drag it all the way under my arm back home.(without locktite)Can’t wait!
My Build is done. It is ready to be taken outside!
