Hi,
Recently I made a bet with my brother that I could achieve 35mph on my board, I live In London so the roads aren’t great, but they are manageable
Here is my build please tell me what you think(and if it will work)
This is a dual rear driven setup …
Vesc: focbox unity
Battery: 12s5p Samsung 30q by @Tinp123 (great builder and sick prices)
Bms: 12s beseech bms
Trucks:caliber2
Motor mount: hobbyking mount
Pulleys: 40t abec 3d printed pulley
Motor pulley:14t diyeboard pulley
Enclosure: self built wooden one
Deck: meepo/wowgo style 10’’ deck
Wheels:abec11 97mm flywheel
Motors:currently Tb 260kv 6355 motors(I have been told the erpm will be to high) here is my calculation, if it is wrong I will change to some sk3 or Tb 190kv 6355
A unity can do 100000 erpm
100000/7 poles is around 14200
14200/260 is around 54
12s is 3.7 12 which is around 44(even at full charge 12 4.2 is around 50v)
So the unity and motor should all fit in together
Please tell me if I should reach the speed and also what range I will get
I haven’t bought any belts yet but am looking for some (not sure whether to use idlers)
Thank you any feedback (good or bad) is appreciated
Thank you
