V1.0
V2.0
Electric skateboard wheel pulley (29T | 30T | 31T | 32T | 33T | 34T | 35T | 36T | 37T | 38T | 39T | 40T) for 83/90/97/107 mm Flywheels / Evolve wheels - i tested them with 97mm Flywheels . I recomend for the 80mm wheels up to 36T, above you can hit the pulley to curbs .
They are made from PETG material ! I had no issues with them !
I tested them with my Evolve skateboard for 100+ km`s and they had litle abrasion.
They are 100% compatible with Evolve skateboards : for Evolve, Abec and Kegel wheels, with the bearing inside of the pulley . The bearings are not included !
Or it can be used for other electric skateboards…
I designed in that way, you can take out the bearing (from the pulleys) easy with a skate tool They are 17.5mm wide to fit 15mm belts, but i can make how wide you want (13-20-25 mm wide)
Also have some 5M / 15mm wide belts: 255mm, 265mm +…
V 2.0
My new V2.0 pulleys for Orangatang / Boa wheels, with bolts + nuts are done This is used without the bearing inside it, for any trucks without modification .
They will be avilable from 32T to 44T and 12-23mm width .
Price:
For V 1.0 :
10 Euro /1 pulley (12-17 mm wide)
18 Euro / 1 pulley+1 belt
For V 2.0 :
- from 32T to 38T : 10 Euro / 1 pulley / 12-17mm wide
- from 39T to 44T : 11 Euro / 1 pulley / 12-17mm wide
- bolts and nuts: 1.5 Euro / set
9 Euro /1 belt (15mm wide)
Postage cost:
Europe: 11.5 Euro Canada / USA / Mexico: 19 Euro South America: 22 Euro South Africa: 21 Euro Australia: 22 Euro
Payment can be made on PayPal
If you have any question, just ask
