I am a little concerned since after using the vesc tool to update my VESC firmware, I am no longer able to control the motors. I followed the firmware update instructions to the tee.
(Hardware is 48, and I updated it to firmware 3.34)
I am pretty sure VESC isn’t bricked because
The remote throttle input can be read from the on the screen.
When I spin the motors with my hands, the realtime data shows a change in current.
It reads the firmware update and doesn’t throw any errors.
The things that isn’t working is that it can’t detect the motors. Like when I try to calibrate the BLDC parameters it just can’t detect a motor. I am using Maytech 230kv sensored motor, running sensorless. Not only that but when I use my remote after unplugging the vesc, it does nothing.
Has this ever happened to anyone? Any ideas? I made sure my battery voltage cutoff is correct as well.
Fault : FAULT_CODE_OVER_TEMP_FET
Current : -0.3
Current filtered : 0.0
Voltage : 45.23
Duty : 0.001
RPM : 6.6
Tacho : 3
Cycles running : 0
TIM duty : 3
TIM val samp : 1050
TIM current samp : 3150
TIM top : 4200
Comm step : 3
Temperature : 330.57
Why the hell does it say its 330 degrees when it’s not. Wow. Maybe that’s the problem, incorrect sensor reading?
I followed all the steps, installed the FW, and everything. But I still get
The following faults were registered since start:
Current : -0.3
Current filtered : 0.1
Voltage : 45.15
Duty : 0.001
RPM : 6.7
Tacho : 3
Cycles running : 0
TIM duty : 3
TIM val samp : 1050
TIM top : 4200
Comm step : 2
Temperature : 377.04
So I guess it must be the temp sensors… I wish I could turn the temp settings off. Unless you have any other suggestions I think we figured out my problem. I did buy these ESC’s off a friend who got them repaired.
