For 2019 Benjamin has packed a nice present for the community.
Hopefully next week we will see a release of the Mobile VESC-Tool in the play store.
The new VESC-Tool is super convenient to use and is prepared to work seamless with upcoming hardware releases. Everything is fully automated and in consequence the complete setup is now nailed with 3 to 5 clicks only. Setting up a dual or quad drive takes just as long as setting up a single VESC.
Next week we will show you something brand new.
Visit www.trampaboards.com and don’t miss out the release of the new VESC 6 Plus.
These are some of the new features you will benefit from:
Auto motor detection including sensor detection for all VESCs simultaneously.
Motor detection in FOC open loop
automatic and accurate current settings for motor and battery (can still be manipulated manually).
FW updates to all VESCs in one hit
Configuration of all VESCs in one hit
Profiles (top speed, current limits, power limits, brake etc.)
Profiles changeable while actually riding the board (you can’t feel the switching)
permanent and non permanent profiles
profiles are written to all VESCs simultaneously and instantly
Smooth low speed braking capabilities (braking close to stand still)
Considering 91% of the world population uses android based phones you must mean “does it use Android?” in which case you’re in luck cuz it does! When you’re ready for a new android phone I sell them in the day time
I can add some bling to an Android and lock it down so you can’t do anything at all, and then charge more for the shittiness. Will that do?
Oh, no that won’t do because it doesn’t come with a side order of “Stifling Innovation and making it more expensive to innovate, directly helping China”
Just get yourself a filthy cheap small android based phone and glue it to the tip of the board. Thats a cheap odometer with built in configuration panel…
Really liked the new profiles, I’ve never managed to make profiles work using UART, this should make things easier by just sending a command of use X profile forever or until reboot
@trampa do you know if the new global current/energy/etc is done at a VESC level or VESC tool level? In other words, the tool gets values from all the VESCS and sum them or the VESC that have the Bluetooth module does the math and send the global values?
The funny thing is that you’re pointing out exactly why it’s a non issue, cheap android phones. If apple compatibility is really an issue for anyone I suggest going to walmart and picking up a $30 prepaid android burner phone and use it specifically for programming. Small investment and you can keep your iPhone that way.
