you can downgrade the vesc tool software to ver. 0.95 i think it is. I was having issues with my sons board remote, when i turn the remote off, the motor would start running at full speed. so i still have the older version of vesc tool on my pc so i downgraded the FW on the vesc back to 3.40 and everything is good now. really weird issue.
Anyone downgraded to 3.57 from Ackmaniac and noticed horrible throttle response?
Thatâs not a downgrade, itâs an massive update. The remote is probably calibrated to send a 100+% signal when switched off. You need to change that. Some receivers can be set to give a signal x when connection to remote is lost. This remote is known to send 100% signal if the receiver is not adjusted correctly. Thatâs why itâs on my personal dangerous product list.
Follow the instructions here on how to properly bind the remote. https://forum./t/how-to-bind-the-mini-remote/95
THX for sharing this! The problem with this kind of failsafe is: If you donât know about it, it can also work in the wrong direction, sending full throttle. For ESK8 it should not be possible to adjust it to positive values in failsafe mode.
The pwm remote is set to 1000 start, 1500 mid 2000max. At failsafe itâs going to 1500. Itâs not a failsafe issue itâs when I go off throttle the board keeps going for another second. Really scary in some situations. Think of it as playing online games with 1second ping.
Then stop using it. There is not a lot you can do about it except getting another PPM remote or better a NRF based remote.
Or I can upgrade to ackmaniac again since it works without issues there. Iâm just looking for if I set something wrong or if the stock firmware is supposed to be this sluggish. I almost shit myself when I went full throttle with 2x70Motor amps and when going off throttle it kept accelerating for another second or so. That second felt way longer standing there wondering if I should bail or what.
Just updated for the latest firmware after more than year
Way better setup than before, with both VESCâs detecting simultaneously
The gradual brake at low speeds work but itâs not there yet, when in enter on the full short phase itâs still a big increase in braking force
But overall itâs working way better, changing settings via Metr works all the time, before I always had problems applying modes and all
Do a proper ppm calibration and adjust the pos/neg ramping time if necessairy. The throttle response should be very direct. If thats not the case, something is funny with the remote.
I did try that. Is there anything else I can setup wrong? I suspect that itâs some kind of user error on my end⌠Ticked off a box I shouldnât or smt like that. App should be set to ppm and uart when Iâm using nrf/ble chip and ppm remote right ad then it uses can between the vescs for traction control and throttle. Could the can slow it down?
A lot of friends came back to previous FW version after having upgraded to 3.57. They all complain about the âlack of powerâ calling this FW âthe vealâ (in French, this is not used for complimenting ).
So even if the FW has new awesome features, crazy code lines and so on, the most important is the feeling of the rider. Isnât it ?
And for the 3.57 this is a no-go for most of people, thus keeping them away from new safety features.
If you use the same settings for the motor and battery, there is no difference in power delivery, no matter what FW you use. Motor amps and Battery amp settings are defining how much power your board will have.
The RAMPING TIME might be set differently, but that is a quick change in the App settings.
Once the remote is calibrated, you should have a very direct throttle response. Try a Pos Ramping Time of 0.3 sec. If you still have a delay, your remote probably has an issue. In the input wizard you can see a bar showing the ppm signal. Does that react delayed or immediately?
PPM and UART is correct. Otherwise you will have no App connectivity. CAN will not slow things down.
Iâm not the guy to convince. Just document it for other people.
Actually, Iâm tired to be the after-sale service for VESC âissuesâ (or letâs say âunattended behavioursâ). The project is not UX oriented, we know that well now. But at least, please provide more information or even better : documentation.
I humanly canât shoot a new video tutorial each time Benjamin release a new firmware.
Setup documentation is online: https://vesc-project.com/node/178 The wizards are now pretty straight forward and UX is a lot better than ever before. Setup is super fast now. Things improved a lot!
Ok, so how do you explain that people are still encountering lotâs of pain setting up properly their VESC by their own ?
- âWhy is the calculated batt max at 99A ? My battery will burn !!â
- âWhy is the CAN not working ?â (CAN ID calculation leads to CAN ID conflict 1 time over 255).
- âWhy my VESC Tool app doesnât work anymore ?â (Because during the night, it updated automatically. No backward compatibility = limited mode = need to update constantly)
- A lot moreâŚ
This is all but UX friendly bro.
BTW, nice addition to the documentation. This will help.
A thing I don´t like, when you have a dual motor setup via can-busâŚ
When using the wizzard for the setup, the process detects both vesc nicely, and setup both the vesc, with those ârandomâ amps numbers etc., Same goes for the remote setup. BUT here comes something, you have to pay attention to. Until now, the process setup both the vesc. But if you then think, that those motors amps or braking amps, is totally wrong, and change that in the GUI, these new numbers is only changed in the vesc you are connected to via USB. If you are not aware of that, you could have two motors with totally different settings ??? I still dont think this new wizzard, is user friendly at all(the old was Better), specially not for newbees
I think on canbus, slave vesc settings are completely ignored so doesnât matter what they are. can someone confirm?
Okay⌠Are you sure ? First time running the wizzard , the settings is set on both vesc
