Hey, I’m making some aftermarket wheels for my ONAN boosterX2 and thought someone else might be interested in buying some.
I’m modelling them after the MBS A/T wheels - will be using a TPU filament from Polymaker and printing them. I have a couple of designs. But I think 100mm will not affect the torque and top speed too much but will make for a more comfortable ride.
I will be printing with 90-95A filament - but will use about 20-30% infill with 4-8 perimeters to create a softer yet durable wheel. It has taken a lot of effort and research to get to this stage and figured there must be someone else out there who would want more wheel options for HUB motor boards.
Printed TPU won’t hold up for long I’m afraid,
did this some time ago. ATM I’m doing some pu casting with the same goal (MBS wheel for hubs), I’ll post a short tutorial/build log soon
You should try it anyway, maybe you’re lucky.
I have already done a PLA print but they were too hard. I’m after a more shock absorbing finish, as I’ll be using them on very rough, but still road/concrete terrain.
What print settings did you have - re: infill and perimeters?
I did consider this (mounting the MBS wheels) , but it seemed more difficult and created additional fail points. I was also worried about the axle length of the trucks.
As I already said, the TPU wears off pretty fast, when you do a thicker version it will hold longer but nowhere near a molded PU.
This was my first try to get some feeling for the process. I’m currently waiting for new molding silicone and I’m pretty optimistic it will work almost perfectly if not absolutely perfectly
