B- is the negative end of the battery
B1 should be about 3.7V higher than B-
B2 should be about 3.7V higher than B1
B3 should be about 3.7V higher than B2
B4 should be about 3.7V higher than B3
B5 should be about 3.7V higher than B4
B6 should be about 3.7V higher than B5
B7 should be about 3.7V higher than B6
B8 should be about 3.7V higher than B7
B9 should be about 3.7V higher than B8
B10 should be about 3.7V higher than B9
B+ should be about 0.0V higher than B10
What do you mean by in between and on the nickel
If you mean does the wire get squeezed in between, yes if you don’t add a tab of nickel that’ll fold over the top to connect the balance, that would be preferred
You would be bridging the SERIES joins with what should be 10awg wire… not 12awg.
Those wires are also nothing to do with the balance leads… they’re the main series connections of the battery pack joining the paralleled cells together in series.
