Hello!
This will be my first electric longboard build so be nice . I have done some research for about a month now and I have already ordered all the parts that i need (I think
) . I wanted a build that would be quite easy to put together so i went with these parts.
Sector 9 Carbon Flight Longboard deck 36: https://www.daddiesboardshop.com/sector-9-carbon-flight-longboard-skateboard-deck-blue
"Mono drive r-spec pro+" Enertion: http://www.enertionboards.com/diy-electric-skateboard-kits/single-motor-mount-pro-kit-plus/
Vesc Enertion: http://www.enertionboards.com/electric-skateboard-parts/vesc-standard/
TorqueBoards 2.4ghz Nano Remote Controller: diy-electric-skateboard-kits-parts/torqueboards-2-4ghz-nano-remote-controller/
Turnigy 5000mAh 3S 20C x 3, connecting them in series to get a 9S 5000mah lipo pack: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=35834
IMAX B6 50W 5A Charger: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=31467
This is where I’m at right now:
Edit:
I will also try to make a loop key using a xt90s connector. I will be uploading more pictures when i get all the parts that i need.
I made this sketchy diagram quickly to plan out how everything is going to be connected:
What do you guys think? Any feedback or comments are appreciated.
