The proper module works with Android 8.0+. I’m running one on Android P right now.
HM-10 Transparent Serial Port Bluetooth 4.0 Modules Bluetooth Serial Port With Logic Level Transformation
There you go. The module is at fault, not Android 8
Problem solved !, I could not connect to my HM-10 with my Pixel or Nexus 5 running on Android 8.0, I ordered the Bluetooth 4.0 Modules, and now it works like a charm.
HM10 not compatible with Android 8.0
Bluetooth 4.0
Link plz.
(10c)
Here is the link of the Bluetooth 4.0, it will work with Android 8.0 and above.
IT WORKS!
But not on Android Oreo. I have Android 9.0 Pie Open Beta installed on my OnePlus 6. It’s not flawless. You have to manually resize the tiles and the red/green connection icon is invisible/below tabbar.
I have to further test it but it seems to work with reading values and stuff
EDIT: red/green connection icon had to reset itself I guess. Restarting Metr fixed it.
the hm10 clones, which is probably what u have, do not work with android Oreo
if u got an early model hm10, make sure tx and rx are crossed
Do we know if the clones work on Android Pie?
Pretty sure it’s a firmware thing so… Roll the dice and see what happens?
I wonder if he knows how much a build like that will actually end up costing though. I hope you didn’t recommend more than 10s to him
