Hello everyone!
Posted my first topic yesterday to ask some help about the parts I’m planning to use for my possible first build. Got some great advice from the community so thanks for that! So I thought I would delete that topic and create a new one with the (hopefully) final parts list so it might help other newbies like me in the future
Been interested in building an eskateboard but I have no experience skating so in case I’m not very good at it I don’t want to break the bank on my first build. I wanted to keep this build low budget but not super cheap so it will just break. I have access to a 3d printer (prusa i3) and have experience building drones and a little designing experience in fusion 360.
Could you please help me and decide if all these parts are compatible / ok enough for the build?
Board would be used to go from where I park my car to where I work, ± 4km single or 8km there and back.
And for casual drives in the weekend. Doesn’t need to go super fast since I don’t have experience
VESC: maytech link => 110 eur
Trucks: Caliber II 50 link => 65 eur
Motor mount: electricboardsolutions link => 30 eur
Deck: link => 56 eur
Motor: Keda 63 64 link => 42 eur
Wheels: flywheel clones 83mm link => 40 eur
Wheel pulley: 3d print myself 40T 15mm link. Already printed it, looks nice. => 0 eur
Motor pulley: Aluminium 15 mm link => 8 eur
Belt: 15mm 53t 270mm link => 8 eur
Controller: gt2b, will mod this link => 23 eur
Battery: 5 x 2s 5000mah zippy link => 75 eur
Ball bearings: trixes link => 8 eur
Bms: Bestech bms link => 65 eur
Enclosure: design and 3d print myself => 0 eur
Riser pads link => 3
Bolts link => 4
Voltage indicator link => 8
Led switch link => 8
Laptop charger link => 20
Female dc jack link => 8
Anti spark, electricboardsolutions link => 20
BT module for ackmaniac, buy somewhere => 8
Battery connectors will be replaced with xt150’s. These can be separated from each other to make easy serial connections, can be taken out for maintenance easily and can not short circuit like bullet plugs since they are isolated. VESC will be flashed with ackmaniacs firmware and BT module as suggested by @Acido and @koralle
bms and wiring are inspired by this topic link. Below you can find my wiring diagram, the bms that I’m going to use is the bestech d190, which is charge only.
WIRING SCHEMA NOT 100% CORRECT FOR LINKED BMS CHECK THIS FOR MORE ACCURATE INFO
Whole build comes down to about 589 euros with small electrical stuff (wires, connectors, etc.) and should be easily acquired in europe. I know some parts can be cheaper when ordered from china but the idea of this build is also to show european builders where to find parts easily without having to worry about import duties. Since sourcing all the parts can be a tricky job I’ve found
This seems, at least to me, like a nice budget build which can eventually be upgraded if needed in the future, but one that has all the conveniences (bms, power switch) of a factory build board.
If I’m missing anything or something needs upgrading / isn’t enough please let me know
Cheers and have a nice day!
EDIT: updated parts after comments, thanks for all the help and tips
EDIT 2: updated parts again to accomodate power switch and bms
EDIT 3: updated parts list to use charge only bms, lighter on the wallet Dropped bullet connector idea since this is just a accidental short circuit waiting to happen.
EDIT 4: added first draft of wiring diagram.
EDIT 5: Added xt150 idea and small text changes
EDIT 6: Update wiring schema + vesc firmware description
EDIT 7: Not going through with build but leaving this here to help others
