oookay. So if you are going to do 12S you need factors of 12.
A good rule of thumb with Liion cells is if you want to draw a certain current for your board you’ll need double the max continuous current draw capability. As a result if you do the Samsung cells I listed above a 12S3P (36 cells) would be a great pack size (although pricy) and the Basen cells 12S2P (24 cells) would be a great pack size.
Checkout NKON, they are in Europe i believe
if you buy those cells you will need at very least 12S8P pack although 12S10P or 12S12P would be better because they are max discharge 5.2A
So you are looking at 100-150 Cells and a shitload of weight if you decide to buy those. What I’m saying is they wont work.
If you are trying to save money buy Lipo Batteries from HobbyKing.
I read on the forum that i need to connect 4 cells in parallel. With 36 cells i’ll get 9 of those “parallels” and i’ll wire them in series. But that’l only be 33,3 volts? So do i really have to buy 48 cells to get 50 volts? 3,7 * 9 = 33,3 volts
Edit: I can wire 3 in parallell to get 50 volts with 36 cells, but seems like the “magic” number everyone is talking about is 4? It will be 9450mah, that will be enough right?
For the gearing, why don’t you just by the kit. It will be cheaper. Also, for the batteries, I would suggest getting 37 batteries. Better safe than sorry if you mess up soldering or if you get a dud battery.
Hahaha thanks, didn’t even think of buying a kit! Great, i’ll buy these diy-electric-skateboard-kits-parts/36t-kegel-pulley-combo-kit/?attribute_motor-pulley=13T+Motor+Pulley&attribute_belt-size=265mm+12mm+Wide
and 37 batteries. The BMS should also be fine i guess
Turnigy Aerodrive SK3 - 6374 vs DYI Torque Boards 6374, can someone tell me which one is better? the turning is $80 vs $120 . Im trying to build my first single drive long board but cant decide on the motor. Whats the difference?
Just thank everybody who helped me! I just ordered the parts! I would have ordered the completely wrong parts if it hadn’t been for you guys so thanks!
