I’ve just completed my first build using a bestech 10s BMS and everything is working well apart from the board won’t charge.
I checked all my connections and everything is correct apart from the voltage output from the charger.
I bought the charger from ebay (no longer listed), which was sold as a 42v 2A balance board/segway charger and that’s what it says on the charger itself but I measured it as 24v? Is this expected from a charger or did I get ripped off?
I have given it a go, there is no connection when it is turned off and I have been trying with on. Will have to see if I can source a charger locally today.
Okay, so I got a new charger, 42v 2A. Plugged everything in it charged for about 5 seconds then popped a capacitor… Tripled checked my wiring everything looks correct. I’m at a loss to know what do to.
I know that the batteries work and are wired correctly as they have the right voltage and I have had the motors spinning. I didn’t post the battery pack as the wires are the wrong colors and I didn’t want to cause confusion, black is positive and red negative but here it is anyway:
Balance leads are reading correctly between BMS negative terminal and the end of the balance lead. I have labelled on the first picture in which order they are wired and where the first and last leads are connected.
