@OskarCastrone Hey ! how much would be shipping to France for the PWR box ? Which size is it ? Iβm interested I have solderless modules to test under a board, could be a good match plus eventual padding inside !
@Pimousse Look it up, would you be interested in reviewing the PWR case on your Pir Cac monster ?
I wish somebody whould make thinner long enclosures. Having a 50cm long enclosure that has a 4+ cm height is just too much when you donβt stack cells or a fat BMS on top of the pack.
When you have a small BMS for charging only or you have a shorter 3p pack and BMS next to it, having 4cm or more height is just not needed. It just means less clearance under the deck.
