Hey, great job. Where can I buy those Orangatang kegel wheel pullys and the motor mount you have? Can you post a link? Thanks!!!
My current mount is the v3 mount. It’s been working great I broke a psychotiller mount previously.
I just touched base with the seller of the 15mm drive parts. This was a prototype unit and I don’t think he has the final production pieces yet.
Check out my youtube for how to videos and updates: https://www.youtube.com/channel/UCNftp-gJagmaFEUVjPYLNrg
Thanks guys for the info!
Been slowly working on making my board more complete. I made enclosures for my batteries and VESC so things now look a lot neater and no more velcro impeding the deck surface when riding.
I have a bunch of YouTube videos on my channel showing how I did a lot of the work. It’s linked here http://barnesd.com
Hi. Awesome build. I have one question: where did you get your VESC from? Have you bought aluminium heat sink separetly?
Ollin Board Company. They have an option for the heat sink.
How is the vesc with 12s I’m planning on purchasing the 12s2p fr Miami eboards to pair with the 6374 190kv from jlabs
Haven’t had any problems and your voltage will be lower on li-ions than lipos.
What battery packs are you using? 4 pcs of 3s? How do you charge those? All at the same time?
@Mikaelj Yes 4x3S and I charge them with a Dual Turnigy Reaktor individually. So it takes me 2 charge cycles to do all 4. I have a BMS and charger here I will hook up eventually when I replace the batteries.
where did you get the gears and belt? I am doing a simmilar nuild, and do not want to have tro mill down the motor shaft if I use the torqueboards stuff.
