Isn’t your capacity gonna be 5000mah? For the total battery
How do you calculate it? I was curious becasue they are 2500mAh cells and there is now way its 50,000mAh I am going to plan on making it 10s3p in stead of 2p
okay so if battery “A” is 3.7 volts @ 2500mah And battery “B” is the same
When you combine them both in parallel meaning + with + and - with - then then the mah jumps to 5000. and voltage stays at 3.7 volts.
SO since this is a 2p pack the mah is 5000.
a 3p pack would be 7500 mah.
If you combine 10 of those 3p packs together in series youll get 3.7volts * 10 packs and you get 37 volts.
Sorry i dont mean to insult you im sure you know most of this stuff already just wanted to walk thru it all in case someone else read this
Haha not at all! Thanks!
You only have two batteries in parallel and at 20 amp continuous each that will be 40amp continuous. I would go to 3p so you can have 60amp continuous. Up hills and at high speeds you can easily get past 40 amps.
Thanks! that’s what i plan on doing!
mAh are added in parallel, but voltage is added in series.
if you have a 10S3p using 2500mah cells, what you have is a 36V 7500mah pack.
Essentially a space cell.
http://www.gearbest.com/batteries/pp_254172.html PLUS THE 10% COUPON: 55liuhao (maybe expired, so try FBGBES for 9% off) I just ordered Samsung 25R cells from here, they had the lowest prices I could find, free shipping, and people say their cells are authentic (both on vaping forums and the product’s review page. They also have LG HE4 cells for similarly cheap prices (they’re out of stock for the flash sale, but their normal price is only $1 higher for the 4 pack). I chose the Samsung for their slightly higher continuous discharge rate since I’ll be running a 3p battery.
Wow. I was able to order 4 packs of the Samsung 25R’s like 10 minutes ago. I bought 24 cells for an 8s3p pack. It came out to $83 shipped.
Also, the out of stock is just for the flash sale. They’ll be in stock (when it says the flash sale ends) for about a dollar more for each 4 pack. I think it’ll be $15 for the HE4 and $17 for the 25R 4packs, and then you can use the 10% off coupon in my post above.
You broke it haha thanks for letting me know/ promo code!
Here are some from aliexpress that were pretty good: Note: You only get these prices if you order from their app before their 6th anniversary sale ends.
10x LG HG2 for $42.49 http://www.aliexpress.com/item/10PCS-New-2015-Original-LG-HG2-18650-3000mAh-battery-18650HG2-3-6V-discharge-20A-dedicated-electronic/32626588770.html?spm=2114.13010208.99999999.261.iV9YbG
10x LG HE4 for $35.52 http://www.aliexpress.com/item/10PCS-LOT-New-LG-DBHE41865-2500mAh-Lithium-Battery-18650-3-7V-power-electronic-cigarette-batteries-20A/32351484110.html?spm=2114.13010208.99999999.267.iV9YbG The same seller also has 6x for $21.39 here: http://www.aliexpress.com/item/6PCS-LOT-New-LG-DBHE41865-2500mAh-Lithium-Battery-18650-3-7V-power-electronic-cigarette-batteries-20A/32349241610.html?spm=2114.13010208.99999999.270.iV9YbG
I don’t trust the one below, but if anyone is willing to risk it: 40x LG HE2 Cells for $90 plus shipping (about +$15 for me) http://www.aliexpress.com/item/40PCS-new-LG-DBHE2-18650-rechargeable-lithium-ion-battery-3-7V-2600mAh-Battery-can-keep-electronic/32606262039.html?spm=2114.13010208.99999999.276.iV9YbG
let us know if you do get the the stuff from gearbest, ive heard very mixed results from them.
Sure thing. I heard they are slow to ship sometimes, but I thought I’d give them a try.
Dude you rock!! Thanks for the links. Can’t wait to see your battery pack project!
No problem; It took me a few days of intense research to find all of this
Check out the 2 packs!! They are $8.19 per, so just a little extra, but then 10% off. FYI…When you put em’ in your cart they are only $8.05 a pack… Pretty sweet little deal here!! Thanks again, Paragon!! Good find!! Your tireless research was not in vain!!!
No problem. Some of the stuff is back in stock at the flash sale price. Just got 40x HE4 cells for $127 shipped. The 10% off expired, but here’s a 9% off I found: FBGBES
@JLabs A few of the forum members make them. @torqueboards and @onloop sold them at one point, and may still. @elkick has a shop that sells Vedder’s anti-spark but he added ad fuse:
dont mean to hijack this thread but using this cell would i only need 6 of these for a 6s pack rather than 12 18650s?
