Hi everyone,
I’m refreshing this build thread, after many months of sitting stagnant. I started off with a dream of an awesome cruiser, but had many set backs. Fortunately all of those set backs have turned into great wins so. I present to you Darth Icarus.
Deck: Loaded Icarus Flex 2 w/ Loaded Drop-Through shock pads top and bottom & Riptide #105 Drop-Through Backing Plates
Trucks: SurfRoz 200mm RKP(Red Baseplates, Raw Hangars) w/ SurKeyz & @psychotiller Press on Motor Mounts
Controllers: Enertion Focbox w/Canbus and Traction Control on Sensored FOC
Remote: @torqueboards Nano Remote
Power System: Samsung 30Q 10S4P with Micro BMS (Charge/Balance Only) & 42V 5A Fast Charger
Telemetry: Metr.at Bluetooth Module @rpasichnyk
Enclosure: Custom Icarus Enclosure from @Eboosted
Wheels: Trampa SuperStar(Red Rim, Raw Spokes) wrapped in 125 Black Gummies w/ 10mm axle sleeves @trampa
Drivetrain: TorqueBoards 6355 190kV Motors. 15T Motor Pulley. 50T Superstar Pulley @Nowind. 15mm Belts
Lighting: Four XM-L T6 Zoomable Tactical Flashlights (2 white 2 red) w/ Meanwell LDD-1000H LED Driver. Custom Mounted to BombSquad Nose Guards
- Sound System: 2.1ch Amp, Bluetooth Audio Receiver, 3" 56hz-5khz subwoofer, Two 2" 126hz-22khz full range drivers, Custom Boxes Glassed on BombSquad Nose Guards
