Hey guys could you look trough my wiring and check if anything is wired the wrong way. I am getting a negative amperage when i pull the throttle and i have no idea why.
Startibg from vesc rightside of most upper xt90 is plus wired middle xt90 bottom part of plug is plus bottom xt90 rught side is plus wired
Upper xt90 is plus on upper side of the plug
Middle xt90 has posituve on side where there is a label
Lower xt90 has positive on right side
Oh yeah pls dont look at the wire colours i know they are wrong haha
Oh i didnt mean to do that. I made an xt90 series plug looked it up and checked it. and that one workes so if the part on the right is vague. because of the drawing. its just an xt90 series plug for the 2 horizontal batteries to make them in series.
Ehm no. The red line you drew is the plug (upper left) coming from the anti-spark in the middle of the board. So that plug has no batteries connected. However the line is going towards the end of a plug where a battery is connected.
No I mean. When i pull the trigger. The metr app says it gets a negative amperage. The amperage goes from 0 to a max of -3.5A trigger fully pulled. So my remote connects, my metr app still works, and I dont have reverse enabled.
Oh is it? How would you have wired it up then? I was struggling with the 3x 4S so I thought this was the best way to do it. But its good to hear that I have it wired up correctly.
