The deliverable are as followings:
1 x DiebieMS v0.8 (2oz PCB) assembled. (SD Card and RF module NOT mounted). Components I have stayed true to the original design including the expensive press fit terminals
5 red and 5 black x wire connectors (non-crimped) for battery and VESC 4x.
1x Male 16P connector
20 pcs non-crimped terminal for balance cables (some are spares)
1x Momentary switch
1x OLED 0.96 Display
4x single end male connector with cable (JST 1.25mm 5p, 10mm) (Display, switch, canbus)
1x single end male connector with cable (JST 2mm 4p, 10mm (VESC side can bus)
6x M5x14 spacer screws
1x 80A Fuse
Asking for 120USD/pc shipped to major cities around the world via Hong Kong Post with tracking Number. (~8-10 days) destination tax and duties not included. PM if interested, I will create PayPal invoices.
10USD/pcs goes to @JTAG as donation for the great design.
The new batch will start when I have received ~50 pcs interest. Would take around 4 wks to make.
**** Remember to use CC/CV power supply with the BMS.
If it works the same as in Germany then you will need to pay VAT but only if it gets picked up by customs.
Some times people get lucky, other times people don’t get lucky.
Quick update, we have 10 so far. For those 10 who filled the form, can you send me your email via PM so I can keep track of you guys, instead of asking at the end.
I have added email request in the form for any future interest.
you’re getting 2 so you can have a backup or did you need it for 2 builds? I was thinking of getting another one as backup in case I break it but I havent heard of anyone actually breaking one of these things under intended use/operation
I do hope that @JTAG implements the USB C by the time this gets finalized and production starts so maybe we can get that feature on this batch? Could be wishful thinking at this point but who knows?
I read the original DieBieMS thread and tried to comprehend as much as I could but I’m not sure if they USB C feature will be possible to add via hardware or software in if it doesn’t make it to the third batch.
