I feel like a total noob typing this out but my searches didn’t yield much info. With longboards it seems customary to mount the trucks with the bushings outward as opposed to inward on usual skate trick decks. Does it really matter which way though?
In my current build, I want to reverse mount my motors, but the Boardnamic Mounts are kind of short, and I could get the angle higher if the bushings weren’t in the way and I could mount them inward.
Hey my friend. It all depends on what trucks you have. If you have longboarding trucks then they will be most likely reverse king pin or RKP and will have the bushings outer. If you have traditional trucks or TKP then the bushings will be on the inside. Facing each other. Never reverse either.
In theory if you reverse, tighten, and lower the angle of the back truck you get a sliding motion but a massive turning radius, its a bad idea and you shouldn’t do it, but you can
The pivot/cup always goes toward the end of the board, away from the rider, regardless of where the bushings are. The bushings will be on different sides depending on if it’s TKP, RKP, DKP, or NKP
That deck is really designed for RKP trucks but its on the short side for a longboard so if you want it to be carvy then you could go TKP. Keep the thing under 30mph though. RKP are designed for stability at speed so if you want to go fast then RKP all the way and do some reading on angles and bushings.
If you want that deck but longer than buy a Minority Downhill on Amazon…RKP Paris clones but the wheels suck…very nice at speeds even with cheap 90mm ABEC clones
