Idea
December 7, 2016, 4:15pm
1
Hi
This morning I presented Mountainboard with electric drive.
Hello My name is Tom, I live in Poland and I like to design and build various inventions. 🙂 I would like to present your project Mountainboard with electric drive. My English is poor, so I’ll write a little, but instead will be a lot of pictures. ...
Reading time: 11 mins 🕑
Likes: 267 ❤
Earlier also I built several electric longboards
I present the last version, a simple construction without a BMS, using conventional LiPo batteries.
Components:
DECK Globe - The Maiden
Turnigy G160 245kV
ESC FVT 120A 6S
ZIPPY Flightmax 8Ah 6S (2x8Ah 3S)
TRUCK - Caliber 2 44
ABEC 11 Flywheels 83mm
Remote Controller 2.4 Ghz nano
Technical parameters:
The maximum speed of 36km/h
Range up to 22km
MotorHolder made of stainless steel and PETG
Enclosure Lipo is printed with the PLA
Pulleys made from ABS+ on a 3D printer
MotorHolder apart from the motor also includes ESC, the receiver RC and switch
However, you can mount a large motor such as SK3 6374
Or two smaller ones such as SK3 6354
I did also versions of the motor holder for Paris180
Transmission belt HTD5M has a ratio of 15/36
Pulleys printed on a 3D printer with ABS
I produce pulleys for ABEC 11 Flywheels and Kegel Orangatang
Enclosure Lipo is printed with the PLA it contains LiPo ZIPPY Flightmax 2x8Ah 3S and capacity indicator
Sorry for my english if something is not understandable
Looks very nice. What’s the belt width on the one with the two SK3 6354? And do you have drawings for the motor mount one could get?
Saw this on facebook. Looks good
That’s a slick looking motor mount setup, well done.
Very nicely designed board! Super clean
wow, very unique. love the innovation in this community
Randyc1
December 7, 2016, 11:17pm
7
Very nice mounts !!,…how durable are those Wheel gears ???
lox897
December 8, 2016, 12:03am
8
What 3d printer do you have?
Idea
December 8, 2016, 2:53pm
9
Thank you all for praise
http://www.electric-skateboard.builders/t/efx2-globe-the-maiden-caliber-ii-44-esc-fvt-120a-6s-lipo-8ah-6s/14323/2?u=idea
Single engine belt with a width of 15mm
Two engine belt with a width of 10 mm (but I want to do on 2x15mm)
I’m sorry but I do not share the drawings because it sells the motorholder, will soon be a newer version of the front of the stainless steel
http://www.electric-skateboard.builders/t/efx2-globe-the-maiden-caliber-ii-44-esc-fvt-120a-6s-lipo-8ah-6s/14323/7?u=idea
Durability pulley made of ABS + is the distance 400-500km
In the previous longboard I drove 450km on the pulleys made of ABS
Soon (for 3 days) I will show PHOTOS pulleys after driving distance 200 km. I drove about 200km both the Longboard and Mountainboard
http://www.electric-skateboard.builders/t/efx2-globe-the-maiden-caliber-ii-44-esc-fvt-120a-6s-lipo-8ah-6s/14323/8?u=idea
GATE 3D printer 3D Polish company 3novatica
Idea
December 30, 2016, 9:16pm
10
Motor holder before assembly
and assembled
Idea
January 1, 2017, 7:34pm
11
New 40T pulleys for ABEC11 Flywheels
As someone interested in the details here
really nice motor mount combo and impressive 3D printing arsenal!
Idea
June 4, 2017, 10:02am
13
Small upgrade, 97mm abec clone
Do you by any chance sell those fancy mounts?
mmaner
June 19, 2017, 6:39pm
15
Im gonna need those STL files for SCIENCCCCCCCCEEEEEE! .
I have a freeboard deck, enclosure and x2 VESC’s Ive been looking to use for a new project, this is looking like the one. I’m thinking black carbon fiber vinyl on the deck bottom, black stained top with red racing stripes cut out of grip, 3d printed wheels pulleys/inserts and motor mount in red, paint the aluminum parts black and assemble…add some rgb lights, in red of course, to the bottom of the the deck and call it KIT 2.0.
Idea
June 19, 2017, 9:04pm
16
@mmaner
Thank you for your suggestions, but I have another idea for modifications:
Changing the motor mounts to new made of stainless steel and aluminum
Changing one motor to two
and in the near future
3. Changing ESC FVT 6S to Dual FVT 12S
4. Changing the battery pack from 6S to 9S
So you would you recommend that fvt to someone who wants an easy setup unlike vesc?
Idea
June 19, 2017, 9:38pm
18
I do not recommend because ESC Dual was not used yet.
I have to test this ESC, I do not know if it is OK.
I tested ESC on my desk only
Looks pretty good so far no problems it looks like, what was temp at end of test?
Idea
June 20, 2017, 11:09am
20
ESC was cold, but without the load tests did not make sense
