Motor mount and pulleys:
: product/single-bolt-on-motor-mount-with-drive-wheel-kit/
Please tell if anything doesnt work, and give me suggestions. I already have an eboard(benchwheel), but it is a little bit too slow and i wanted to start a diy project.
Also, if you know a good calculator for the top speed, please let me know.
Looks good. What battery are you getting? Make sure to get the Kegel drive wheel and not the ABEC one. Do you know how to solder because you might have to? You will also need a cable to connect the VESC to your receiver.
The distance does not increase just because you hook batteries up in parallel. It is about the wh and they stay the same no matter if you connect in series or parallel.
exactly. As long as you limit your speed on 12s you’ll still get the same distance as a parrellel set up. You just have the option to go much faster if need be
Since everyone else commented on the batteries, I’ll comment on the motor and VESC. In my opinion, I think the may tech motor is over priced. For about the same price as they quoted me, you could get a great motor from enertion or Motors. I suspect the VESC from them will be about the same, and I don’t know if anyone has tried them so I don’t even know if they’re decent quality. I will say that I doubt that they’re supporting Vedder and the electric board community anywhere near as well as the other VESC sellers are. Food for thought, I won’t rail on ya if you want to go maytech anyways. Welcome to the community though!
thank you for the calculator. I think i´m going to put 2 batteries in series so i can get more speed(the batteries are where it says ‘akku’). I have do ask maytech whether i should take 10s or 12s. Where do i find these cables?
