Edit: please answer the questions below before reading this. You might had caused an issue if it’s exactly what I’m thinking the red blinking means.
This means that you haven’t fully installed bootloader from the firmware menu. I’ve had this issue on the MakerX retro. It was supposed to be Firmware 5.1 (was on a different version). Everytime I hit firmware, it would say I did it, but when I unplug my battery and replugged, it would revert to older software.
Here is what I did. And note that my firmware was 5.2 as well. So this should help you:
The proof that I am on old firmware.
Went to firmware and went to bootloader first. This is very necessary to remember. If you did not press upload all, your esc WILL reset itself to 5.2 due to one side. If this happens, you have to also update the other side with the USB cable. That’s why there’s two.
Always check to see if there’s another bootloader by clicking on the name seen on screen first before uploading all.
Once done, both sides should be updated with upload all. If you only chose upload, it will only do one side, so you have to unplug the USB and do it to the other side.
Once you do this. You must click upload all and check and make sure your settings are right.
If done properly, the results are this:
When you see this, count to 11 and then unplug your battery. Note: this is the thing you’ve mentioned to me. I never needed to do this tbh. That’s why I have very little knowledge.
This should be the finished results. As you can see, I’m on 5.3 and every time I disconnect the battery, I’m still on it.
My results.
The only time you would need to do what you’ve given is if you had done both sides of the bootloader and it did not update afterwards. I only seen it used for the unity tbh. I never needed it so I have very little knowledge. Sorry mate.
