Because I plug mine into my GT2B and all I get is light. No throttle response does anything to affect those lights. The only video I could find about setting up these lights is by hobbyking, and they show you plugging one cable into the reciver and one into these light ports on the esc. No matter what port on the receiver I put these into, nothing changes.
I think i figured it out. It has to be on the same channel of as the throttle, meaning I need to combine the esc servo wires and the servo wires for the lights together.
However, it controlled my headlights when I braked, not the taillights.
haha keep going you will get it eventually… swap the headlight ant the tail light plugs.
that particular kit doesn’t come with turn signals, but it is the same theory, but instead of plugging into the brake channel it plugs into the steering channel and the lights light up when you turn the wheel of the GT2B.
oh shit. Its on now. I might have to impulse buy this kit right now and re-work the leds to be embedded in my deck.
Also its worth mentioning that it should work with ANY steez remote if it works with enertion’s. Carvon sells them too, that’s where i got mine. Its the exact same remote.
I’m getting weird results switching it around the other way.
It could be my controller needs charging, but it worked once, then it got stuck dim, and wouldn’t go back up to bright, Sometimes I turn it on and the tail lights are on, sometimes, they are off. If they are off, sometimes, they come on when I hit the throttle or brake, and sometimes, they stay off. I double checked my soldering and it all seems good.
Head and tail lights worked flawlessly on a 10 mile nighttime shake down. Gives plenty of light, combined with a helmet mounted light I felt very safe and well seen
Quadcopter Lights 1.5w … Best set up so far…clean easy to use and super bright…run the wire under the truck…the light has a metal stem at the end of the metal casing so you can put it right up against the truck… I suppose you could run a small channel …
@torqueboards@RunPlayBack I went ahead and added a second light and a red tail light. I need something on my pack for vertical visibility but I think I’m pretty visible already with this setup.
I agree @Michaelinvegas! Night riding is now my favorite! There’s less traffic, less noise, and there is something peaceful about only really seeing 15-20ft ahead all the time. I still ride during the day to get around.
It’s the only way I can ride around old Las Vegas without being a hood ornament…one of my fav place to roll around is San Diego…fun stuff the gas lamp district at night
