Hello,
First thing: I’m not a regular member, I work towards it… So i can’t take money in front. So if you want a pack, you can contact me. I will make it and when it is made. Then you can pay.
I live in Belgium so i can ship to the whole EU.
Instagram: https://www.instagram.com/custom_liion_battery_packs/
Pack specs:
You can choose your own battery configuration.
For the pack i use 10x0.15 40A 99.96% Pure Nickel. I use always two layers ore more of nickle. So the pack can give enough amps.
The output wires are 12AWG (80A+) silicone wire . An upgrade to 10AWG(100A+) is possible.
The prices below are with heatshrink, output wires & xt60 connector. It is excl BMS!
Asking publicly for now because maybe others might find this useful…
I’m interested in buying a 12s1p battery pack from you (possibly 12s4p in the future), and was wondering if you could use a different BMS from the ones you listed, because not having to pay for both a BMS and an external e-switch seems like an attractive idea, but the one you offer is only for 10s. Could we work out a deal? Or maybe (as you have more experience) you’d suggest me a different setup? (I want 12s because I’m planning on running 170kv motors )
Most BMS’s are specifically made for a certain series, but I would recommend trying to get a DieBieBMS that’s developed on the forum, it can be used with different number of series. @Samau18 is making some now, message and see if there is any room for another order
Hi man! If i had not already bought everything to make my own pack would I definitely have bought one from you. You’re prices are really nice But there is one thing im curious about:
How can they take a maximum of 40A? Wouldn’t the maximum for a 10mm X 0.15mm be 13.42A
Also: would you mind showing how you weld the 10S6P packs together? and what spot welder do you use?
I used a long time the nickle they sell on ebay, It was advertised as 40A nickle. Now I’am using nickle from Nkon.
I use in my packs always, 3-4 layers of nickle so the amp draw will be no problem.
I am using a Sunkko 709ad spotwelder. You can choose how you want the config off the 10s6p pack.
I made all the packs costom made.
Howdy
looking to have a pack built for a trampa…so groups connected and shrinked in sets of 4 or fibe, with wire for flexability. thinking 10s4p or 10s5p. think you could swing this?
