To get faster performance, sometimes you can use lookup tables instead of calulating the floating-point numbers.
sometimes…
sometimes…
add a 32 core cpu to your system
It’s not the problem of cpu performance, adc, pwm they all have maximum speeds I mean yes you can build fucking monster with oscilloscope level ADC, external PWM generator which uses freaking LVDS connections But who will want to pay several K for speed controller to drive 60$ motor
the day i have to much money
If this turns out to be plug and play by simply inputting a few basic parameters and is dependable, you will be an e skate hero! Sign me up!
Why so humble?
I edited my post to be clear I talk about an uncooled aluminium enclosure like mentioned in my first post. So no airflow and sitting in room temperature. I also said that constant current for several minutes isn’t used in our application, but it is a good benchmark because it is easy to reproduce with different hardware at same conditions and it is not dependent from riding speed and mounting for an example. (different airflow) On my ESC I am also using 150A motor current without a problem, but not for several minutes and with good airflow cooling the case. So I never said 100A are not possible. Just not with your FETs, a normal aluminium case without airflow at room temperature and running it continuous for >15 minutes. Good luck with your project and I am out now.
@Kug3lis I am eagerly waiting to buy a dual setup of these for my board… I was gonna buy some of stewii’s controllers in September, now these are what’s going in my monster… we have a race track, drag strip and I have obtained permission to take my board on it… I’m gonna try and top out an 18s and get it clocked lol
i need this for my upcoming setup
Any updates?
Still a shit load of work on firmware so don’t expect without end of year or next year spring
So what you’re saying is, we should start the pre-order Group buy thread. LOL
Oh no not yet I am still working on firmware level stuff, afterwards I will be deciding what hardware to make as logic (mcu and firmware) will be used the same on all hardware configs I have achieved motor spinning, now I need to implement PPM, configuration, usb, uart, can and other stuff
Oh I know, was more a joke on people and thier impatience for new products.
Plus we need time to design body armor to Keep Us Alive at 19s
Plus I am evaluating DRV for 100V operation from TI Maybe it will go into production at the same time I will finish my firmware
You almost got me there on the pre-order thing lol
Would our standard 6374 motors handle your 18s esc (at say 16-18s), or would we need different motors?
Each motor has maximum RPM or Voltage allowed Its mainly for beefier motors like 80**
@Kug3lis Do you think your ESC will be suitable for more powerfull electric vehicules, like scooter, motorcycles, powerfull ebikes ?
I am looking for other ESC than chinese ones
Well I am making new main brain of esc which I can reuse on mostly any hardware stage. so from mini version for 6s 30a max up to bus motor controller but I doubt I will make something for bigger vehicles as there are better options
Bike has already nice controller
http://adaptto.com/Products/Controllers/
P.S. this design in topic is dead so no more like this as I am using different mcu and etc things
