@3DServisas replacement seals available?
Yes, V-ring Shaft Seal is available. You can search online stores. VA-050
Ive ordered these drives but in order to work on a custom talon deck design and some TB218s and i could really use some of the dimensions of the nano drive. (already checked website and thread for them)
Would you have a drawing with the dimensions on if possible? or if you could share privately as im really eager to know if customisations are needed to a talon design using your product.(an answer i assume many more here would like to know too)
FatBoy Nano with Bergmeister Wheels
Hi buddy, couple of questions for you?
what KV motors did you go for with the 2.67 ratio and the bergmeisters? 130 or 150KV?
what is the length to cut the motor shaft so it fits the nano gear drive?
@3DServisas this pic totally helps me make up my mind in using my Bergmeister or Abec adapters with my Evo
It depend of your voltage and what speed or torque you want, make some test with a calculator
yes exactly i see you are very quick to try and flame people for asking relevant questions⌠on a li-ion 10s 130kv would hardly do 20mph real world and 150kv 26mph
already done the esk8 calculations hence i put 130kv or 150 hoping to gain insight of another person doing the sameâŚ
I guess it language barrier here (once translated, youâre really not coolâŚ)
sorry to try to help you mate !
I use the 130kV btw
What enclosure is on the landyatchz?
Good print e-riders
wow thanx, you just saved me some time
You also planning to make them for the mtb gearbox version?
youâre welcome
Sorry, I didnât get the mtb one, so I canât âŚ
would this thing work well one a vanguard deck?
I guess yes, my Arbor Axis is a (just a little) bit the same outer shape :
Also, the bigger version :
