Hey there,
This lovely community has introduced me to an expensive addiction. After spending a lot of time reading through this forum, here is my planned first build. Planning to spot weld my pack. Let me know if I am missing anything or if y’all have any recommendations.
Deck: Old Longboard, 1080 mm long
Wheels + bearings: https://www.ebay.com/itm/Blank-Pro-90mm-Black-Longboard-Flywheels-ABEC-7-Bearings-Spacers/143067902765
Trucks:
https://www.amazon.com/Caliber-Trucks-Cal-50°-Longboard/dp/B014JWQ8M8?th=1&psc=1
Motor: Going with the 6834 200kv
Motor Pulley / Mount: (Need this 12mm motor pulley not a 15mm as included in the DIY)
Wheel Pulley - (Ask Dickey if he has black cus black is sexier then silver)
VESC - from a lovely friend, 4.12, no FOC
XT90 antispark x 3-5ish
XT60 x 3-5ish
BMS -
Built in antispark loop key switch
Controller - Enertion Nano-X, if used, anyone selling one? Or maybe this, its damn cool: But I probably don’t have the skills for it.
Batteries: X40 - 10s4p (we gettin that range baby!)
LION Charger-
https://www.amazon.com/EVAPLUS-Lithium-Electric-W15155059014-QCF3601P1A100/dp/B073QKZGT4/
Charging tip from buddy
Nickel for spot welding -
Black PVC Heat Shrink Tubing - 180mm
Insulating cardboard paper -
Enclosure - Going to 3d print
Misc -
12AWG wire x 3 feet https://www.amazon.com/BNTECHGO-Silicone-Flexible-Strands-Stranded/dp/B00TG1TSUC/
18AWG wire x 3 feet https://www.amazon.com/Electrical-Gauge-Silicone-Cable-Black/dp/B0746HMTPP/
Loctite
Threaded Wood insert
M4 x 10mm threaded insert: https://www.amazon.com/uxcell-Threaded-Insert-Socket-Assortment/dp/B07GKVQ4C2
M4 x 16mm screws: https://www.amazon.com/Prime-Line-9131208-Machine-Phillips-Stainless/dp/B07D5S32CZ/
Do I have everything I need? Will this be a solid build?
